alexliz
Pre-canned entries in pop-up fields in Zones
Anyone can point me to where I have to go to edit and/or add values to these pop-up menus, in order to customize Zone settings for the needs of each project?
Archicad 29.0.2 (3200) INT; macOS Sonoma
1 Solution
CosminF
Correction, I thought wrong, you might want to look here: https://community.graphisoft.com/t5/Libraries-objects/Zone-Tool-Flooring-Types/td-p/242082
Details is the same issue you're facing and how it was solved
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
3 Replies 3
CosminF
Those options can be adjusted in the property manager:
CosminF
alexliz
Amazing, @CosminF , many thanks. I read Laszlo Nagy's explanation and have now successfully created a new Zone stamp and associated macro, with all my custom values.
