Printing Multiple Layout Sheets as Single Document
Matt Balaam
Hi all,
I have a feeling what I want to do is not possible, but hopefully someone knows a way...
Using AC14, what I want to do is print multiple pages from the publisher (using the print option, not the save option) as a single multipage document. Currently, the print option sends each page individually.
The reason I want to do it this way is we use electronic document storage in our office which has a printer that can save directly into the storage. What I would like to do is have ArchiCAD print the layout sheets as a single multipage document which can then be stored, rather than a group of individual pages as it does now. Microsoft Word for example will 'print' a multipage document using this printer perfectly, but ArchiCAD doesn't seem to be able to.
I know I can save to a single PDF then print this file into storage but would like to remove the extra step.
Does anyone know of a way to do this?
Thanks
AC24 (7000 AUS FULL)| Windows 11 | Intel Core i7-12700 @ 2.1GHz | 32GB RAM | NVidia T1000
David Maudlin
Matt:
One method is to select the layouts you want to include in the Navigator, invoke the Print command, and then check the "Selected Layouts in Navigator" option under Print Area in the Print dialog box (this is on a Mac, I don't know if there are any differences in Windows).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Matt Balaam
Thanks David, works perfectly!
I tried this option yesterday without success but I just worked out the problem, it was to do with using the Organizer (read below)
For anyone else trying this in the future, there are a few little quirks in the process:
  • - You have to have a layout window open for the option to be available, it wont be there if you are in plan view regardless of what is selected in the Navigator.
    - If using the Organizer you have to make sure you select the desired layout sheets in the left window for this option to work properly, selecting them in the right window wont work.
    - You have to select the actual layout sheets, selecting items in the publisher list wont work.
David Maudlin
Yes, I had forgotten to mention this, glad to see that this worked for you.
