Printing from archicad 7.0 Pdf
Hi!
there is a way to print or save from archicad 7.0 , to pdf?
Thanks
4 REPLIES 4
Yes, you should be able to use a PDF printer. Google CutePDF for one example. There are lots of others.
It basically installs itself as a system printer, which you can select in ArchiCAD and print to it which produces the PDF.
Thanks,
I apprecciate you suggestion
nabritta wrote:
How do you reduce the size of an indesign file so I can email it and not make it a pdf? I want to email the actual indesign document so that the person can open it in indesign and change things. I don't want it to be a pdf. Right now it is to big of a file to upload to email. I need to reduce it.
You may have more luck asking in an Indesign forum. Try here for example - http://forums.adobe.com/community/indesign
nabritta waited a couple of days then put some spam links into his signature.
So he was banned.
"Nice try."
This is why only Peter's answer is visible in the thread but not nabritta's original question.
