ā2012-07-07
05:59 PM
ā2023-05-26
04:38 PM
Rubia Torres
ā2012-07-07 07:51 PM
ā2012-07-09 04:41 PM
ā2012-07-09 09:15 PM
ā2012-07-09 11:21 PM
ā2012-07-11 12:06 PM
Kent wrote:I had about 6 crashes this morning on Archicad 16. It is VERY unstable. I'm disapointed and the worst is it gets worse when I load my Cadimage Add-ons! Why!!!
Thank you for your reply. Sorry for unable to upload the simple file as it's larger than the upload limit.
Another disturbing thing is that the computer often crashes when I try to save any model.
It seems that Archicad 16 is quite unstable for my computer.
ā2012-07-15 08:33 AM
Karl wrote:The Archicad 16 crash problem is solved without installing the "Objective, Cigraph, Cadimage" add-on.
Yeah, I meant to upload to a some file sharing site - dropbox, for example. File attachments here are limited to quite small sizes.
I haven't had any crashes with the release version of 16. Are you submitting the crash reports when this happens, and following up with a contact to tech support with your bug id / crash number?
ā2012-07-15 12:32 PM
ā2012-07-15 01:32 PM
ā2016-08-25 12:41 PM
gpowless wrote:Here we are at Version 20 and MEP display is still not fixed. Should I just junk the MEP add-on or is Graphisoft still interested in making their tools work correctly?
I have had the same problem with MEP since V14. Depending on the part of the system, it jumps to another storey and I have to go searching for it and place it on the correct storey.
I only rarely use MEP since the HVAC designs that I complete are documented faster using a 2 line layout method. When I do use it for things like modelling septic systems or in-floor radiant I just live with it.
