Published PDF images with jagged edges
Any idea why these 3D views are coming up with jagged edges when published? They look OK on the layouts inside ARCHICAD.
Thanks.
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
  • Are those general 3D OpenGL views? It looks like it tries to generate some kind of transparency/Antialiasing thing, and it fails.
  • Please see what happens if you save it to PDF (or if you saved it to PDF before, then try printing to PDF).
  • Does the same happen if you do it on a different computer?
  • Also, as a solution for the meantime, you can try using 3D documents instead of 3D views. They are vectorial so they should not be prone to such errors.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
