2020-01-31
09:14 AM
2023-05-19
10:07 PM
Gordana Radonic
2020-01-31 10:37 AM
2020-01-31 03:18 PM
2020-01-31 11:41 PM
2020-02-02 08:32 AM
Llian wrote:Try double clicking on the warning icon and you should see what the warning is.
The other thing, what does the yellow warning means here?
2020-02-03 08:12 AM
2020-02-06 09:33 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-06 12:14 PM
2020-02-07 08:30 AM
LucaP wrote:Hi Łukasz,
Hi Minh,
Since we're talking about the "long path issue", do you by any chance know if Graphisoft is planning to implement the possibility to use relative paths (i.e.: external drawings, publishing setup etc.)? Being able to use relative paths based on PLN file location would be a great help.
I wonder if that issue had at least been discussed by developers (there is a wish from 2004 about a secondary path, and another from 2018 about relative publishing, but none of them seem to be addressed by developers).
Łukasz
Minh Nguyen
GRAPHISOFT
2020-02-07 09:57 AM
mnguyen wrote:Thank you for taking effort and reporting that wish. I really hope that this will be easy enough to make it work in near future. (Next release perhaps?
Hi Minh,
Łukasz
This is a known wish that actually dated back in 2002! To be honest, I won't be able to comment on the implementation of this (not sure how hard it would be). This was put into Filed state, but I really am not sure if this would be possible to happen.
Anyway, I have placed another comment into the wish entry (same as you, I think it will be wonderful to have relative path, so that we won't have to relink libraries, hotlinks, and drawings every time the file is copied/saved to another machine!). Please refer it in the future as #1369.
Thank you very much for raising the question. I wish you a great day!
Best regards,
Minh
