Publisher Sets and content removal?
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 REPLIES 4
I don't see your View Map so I don't know exactly what items are its source.
But you can try deleting it without much risk.
Save your project file, delete them, see what happens. If View Map items or folders are deleted, simply close the Project file without saving and reopen its saved version.
rob2218
huh...very good.
laszlonagy wrote:
I don't see you View Map so I don't know exactly what items are its source.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
ok...deleted...done.
nothing seemed to have happened.
What does that "Warning!" with a big exclamation actually means?
I sometimes will get warnings like this about clone folders. that if you delete a clone folder.....something something something...and then when I delete the cloned folder...all the 'original' folders disappear too and I can never tell exactly when is it that I "can" delete something like this or not.
most confusing at times.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Time to visit the Help Center?:
http://helpcenter.graphisoft.com/guides/archicad-17-guides/archicad-17-int-reference-guide/documenta...
The above page talks about creating items in Publisher Sets and the difference between using the Add Shortcut button versus dragging items to Publisher Sets.
Of course, the Add Shortcut button is based on the Clone Folders concept of ARCHICAD so the below two pages will also be useful:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/interaction/navigation/navig...
http://helpcenter.graphisoft.com/tips/archicads-powerful-clone-folders/
