2026-07-04 01:45 AM
Hello everyone,
I'm experiencing a strange Publisher issue in Archicad 29 INT (macOS) that only affects one specific PLN file.
When publishing a Layout Book:
I've already tried the following:
The important part is that:
This makes me believe the problem is specific to this PLN file.
Has anyone experienced this before or knows how to repair the Publisher or project database without rebuilding the project?
Any suggestions would be greatly appreciated.
Solved! Go to Solution.
a month ago
Can you alter the names of what you are saving?
I see there is a dot (.) before each name.
I find it is good practice not to use dots in file names as that is the file extension delimiter.
a month ago
First of all, thank you to Barry, Karl, RyeJuan, and everyone who helped me troubleshoot this issue. I really appreciate all of your suggestions.
After hours of testing, the solution turned out to be surprisingly simple.
The problem was that my Publisher Subset did not have a Custom ID assigned (first image).
All I did was add "CRD" as the Custom ID (second image), and everything immediately started working. Publisher now exports both PDF and DWG files correctly.
What made this so confusing was that Publisher always reported "Saved", created the folders and Xref images, but never generated the final PDF or DWG files.
I honestly thought my project had become corrupted and was already planning to rebuild it. What a relief!
Hopefully this helps someone else in the future.
Thank you all again! 🍻
2026-07-04 03:46 PM
Are you saving to a cloud folder or drive?
If so, try saving to you local hard drive or a network drive.
2026-07-05 06:21 AM
Thank you, Barry.
I appreciate the suggestion. I have already tested publishing to a local folder on my Mac's internal drive (Desktop/Documents), so the issue does not appear to be related to a cloud location or network drive.
Here is what I have confirmed so far:
At this point, it appears to be something specific to this PLN file or its Publisher database rather than the output location.
Has anyone encountered a similar issue where the Publisher reports success but never writes the final PDF or DWG files?
a month ago
a month ago
…and more than that… macOS is a Unix based operating system and file names beginning with a period are invisible in Finder.
a month ago
That would explain why they say they are saved but iggiv can't see them.
Thanks Karl.
a month ago
have you tried selecting this option in the publishing set properties?
a month ago
Good morning everyone. Thank you so much for taking the time to help me solve this!
Regarding changing the file name with the prefix number, I could definitely look into that. However, AC automatically saves the file, so it seems to be working as expected. It seems to be related to the floor level. But since AC28, this hasn’t been an issue, so I’m guessing it’s not the problem.
a month ago
Good morning Karl, thanks for getting back to me. As I mentioned to Barry, I believe this is not the issue. The prefix number only appears when saving files, but not when naming the save files it self.
a month ago
Barry:
I’m not sure if this is the problem, but I’ll give it a shot to see if it is.
However, I need to run another test first. I think I’ve come up with a new theory that I haven’t tried yet. I’ll post it at the end.
