Publishing 3D PDF, cant attach U3D to layout.
So... I'm working on a small house project for a client of mine. And I thought it would be nice to send him some 3D PDFs of his "soon to be" house.
But I can't seem to add the U3D file in Archicad...
http://www.archicadwiki.com/U3D this is the guide I used.
I'll try to explain what I did.
1. I found a good 3D view of the modell, right clicked and used "Capture window for 3D document..."
2. Went back to same 3D view of the modell and "saved as" U3D file.
3. Added my finnished layout to Publisher sheets.
But when I select "Document Options" -> "PDF Options" I can't check the box to "Embed 3D Content"
Sorry if I can't explain more cohesive as english my secondary language
Help is much appreciated!
Using AC14 running on 64-bit Win 7
4 Replies 4
Steve Jepson
It works. You need to select the layout the u3d file will be in. Then select PDF Options.
I have the same issue that Olausonxsd has posted. The Embed 3D content does option does not appear.
If anyone knows how to make this show up that info would be great.
Thanks
Steve Jepson
It works just as shown above....when it works!
It is not very consistant as far as I can tell. I have been able to do it by testing with the detault template file. It seems to work one time and then not again after that until I close out and try it again with a new file. ??
Once there is 3d view placed on the layout, the "Embed 3D Content" box is activated.
P.S. There are still something strange.
Problem 1. In Layout Book , the 3d View placed on the layout could not seen directly.
Problem 2. In Publish Set, I just check the box "Embed 3D Content" box without choosing any U3D file. The 3d View should be the default "Perspective View" in the published pdf. However once I publish the layout as pdf. It is crash. (Report Already)
Problem 3. In Publish Set, I check the box " Embed 3D content" box and choose one U3D file. It is fine in the published pdf file. However if I place two or more view in the layout, there is only one 3d View shown in the published pdf.
