Quick measuring distances
I'd like to mesure the distance between to objects without using the dimension tool because I don't want it to be marked in the floor plan. I want just to have the idea of the distance in a quick way, like when you use the DI (distance) command in AutoCAD.
Thanks a lot and sorry for such a basic question
1 Solution
You are looking for the Measure Tool: https://helpcenter.graphisoft.com/user-guide/88458/
Go to post
7 Replies 7
Thanks a lot
Is there a hotkey for it in order to do it more quickly ?
I think M is the default. Why don't you take a look at your hotkeys? Options -> Work Environment -> Keyboard Shortuts -> Show in web browser.
It is M, thanks a lot ! and it’s not marked in the list that you told me about.
I’m working my way through ArchiCAD after 8 years of working in Revit and I’m trying to gain the same speed, and Im really missing all the shortcuts. I’m guessing that archicad is more mouse based
Pretty much all commands in ARCHICAD can have a shortcut set up for them in the Work Environment, so if that is your preferred method, you can do it. Although ARCHICAD does not have two-letter shortcuts like Revit does, you can use any combination of the CTRL/SHIFT/ALT keys + normal keys to define your shortcut combinations.
Thanks a lot for your advices, that’s quite kind of you
Guru
With the Coordinates dialogue in your workspace, you could also use User Origin function to measure things quickly. Alt + Shift + LMB (Left Mouse Button) to set the User Origin then just cursor over any secondary points.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
