Rebuild from Source View - visibility settings
Johann_P
I keep on losing the detail lines when I rebuild a detail from the source view.
I've copied the detail as it should display when I rebuild from source view, but I keep on getting a grey image.
Any advice?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
DGSketcher
Legend
It looks like you have a Graphic Override either assigned to the detail or the source view which is changing all the fills & removing skin lines.
Erwin Edel
I haven't made details this way in a long time, but I think if you rebuild from source it will revert back to being the exploded lines and fills from your model (where you placed the detail marker).
We work with independent details and use trace and reference to draft the detail 'from scratch'. However the Dutch subscription library comes with a lot of handy library parts that offer the right amount of detail for detail drawings, so it is quite quick to set up this way.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Tim Ball
That is the way the detail tool works
i recommend you use complex profiles instead
I personally haven’t used the detail tool for years. In my view it’s not fit for purpose
Tim Ball
AC26, iMac
User since V5
