Reccuring plot maker problem....
I have had this problem in the past, and I've never been able to solve it without completely re-creating the plotmaker book, which I cannot justify wasting time on anymore. I print my entire workbook and several pages (seemingly randomly) will print with just the title block and sheet layout on them, but no drawing. What makes the problem even more interesting is that it seems to do it differently with different printers, when I print to my DocuCentre printer, every page comes out with just a title block, when I print to the Adobe PDF printer, about half come out like this, when I print to the Amyuni Printer, only 2 out of 15 sheets come out blank. I have spent countless hours fiddling, and on the phone with my local reseller, and no viable solution has come from it... Please help me out with this, there has to be something Im missing here, I can no longer take the time to recreate the entire Layout book everytime I want to print something...
cheers,
dan
8 Replies 8
Djordje
This does sound like a memory usage problem. I had this happening sometimes when I publish to printer (DesignJet 500, maxed out) and it prints all the sheets - each one half way through.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
memory usage on the printer end or the computer end?
Rakela Raul
printer end
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
this problem is really starting to irritate me Today I needed to add an optional floorplan into a drawing set, so I added a layout page to the layout ook, imported the drawing, and everything looks good, but even if I try to print just the new page, it prints a blank page regardless of what printer I use (document centre, HP laserjet, amyuni PDF, or Adobe PDF)....
any ideas?
dan
any ideas?
dan
Just a guess, but is your title block/border one large view or PMK that is overlaying the plan?
When printed is this masking out the plan?
I know the forward/ backward commands work in Plotmaker as we have some trouble with overlapping PMK's sometimes.
May look OK on screen but doesn't always print like that when overlapping.
Well the title block is drawn onto the layout master, which inturn has the viewset from AC brought in, and placed on it. not sure if thats what you meant by overlayed... if you mean is it a separte drawing thats also placed on the layout, then no..
cheers,
dan
cheers,
dan
Yes I was thinking of two placed drawings.
Sorry no help from me then.
not a problem, I will keep your comment in mind, for future problems though
cheers,
dan
