2005-10-24 06:40 PM - last edited on 2023-05-17 12:56 AM by Gordana Radonic
2005-10-26 04:32 AM
2005-10-26 06:28 PM
2005-10-26 08:11 PM
Richard wrote:Exactly. Some people are not comfortable modeling as much, or do a type of work not conducive to modeling, and model more in "outline" form. You still get a lot of the benefits of modeling without as many graphic and learning curve issues.
David,
I wonder if you weren't entirely understanding what Tom was saying. I don't think he was suggesting that you model everything. I think he was just saying you could leave a simpler model (without unlinking) and add all your 2D detail on top of that, in the section window. This way you get your detail, but leave the model "live" so changes show up easily and don't have redundant linework.
2005-10-26 08:52 PM
2005-10-26 09:11 PM
jdrulon wrote:In these cases, everything that is modeled is used for the construction document. Usually, it is all walls, roofs, and slabs, with simple doors & windows (no trim, sills, etc). Nothing is traced over, and all of it is linked to the model. In section views, the Display Option for doors & windows is set to "Ceiling plan", so that actual windows are drawn in the openings created by the Archicad windows.
When you do as you are suggesting do you try to use any of the information from the model as is or do you trace over everything and put these 2D lines on separate layers that can be locked or turned off? Trying to get the walls, slab and roofs to clean up properly in the 3D mode is difficult and time consuming. Do you also keep the Elevation Window dynamically linked to the model? I am always afraid of deleting a part of the model without realizing it when working in the Elevation Window.
2005-10-27 12:20 AM
2005-10-27 01:57 AM
2005-11-07 07:27 PM
2005-11-07 08:11 PM
Pablo wrote:Sorry, I've been slammed lately and have not been on the board so much. I think part of the key is knowing what to model and what not to. Below are a few ideas:
Tom, I am a newbie when it comes to stuff like this.. can you clip some images and show us what you mean? I have spent a good deal of money buying as many 3D parts as I can, figuring that I will save some time in the CD prep process (i.e., Real Doors & Windows, Trim, ArchiTile, etc.) Is this the wrong approach? I do want to streamline the CD production process.
Thanks.
+pablo
2005-11-07 08:17 PM
ArchiTAD wrote:Same here. Plotmaker's drafting tools are good for break lines and match lines, but that's about it!
Unfortunately, there have always been and always will be extra lines. My office is committed to modeling everything (residential projects) in 3D and reaping the benefits in our construction documents. My staff has become quite proficient using ArchiForma to quickly model elements that ArchiCAD's parametric objects cannot give us (window/door trims, window/door cutups, etc.). Our elevations and sections are always live. I've created a simple "Block-out Fill" favorite that is used to cover unwanted lines, everything is done in ArchiCAD with PlotMaker being used only to publish our documents. In fact, most of my staff doesn't know that PlotMaker has drafting capabilities! Blocking out is usually the last step in our construction documents process. This technique allows us to quickly view our model from any direction and include 3D views in our construction documents, with all building elements shown!
I stopped exploding my sections/elevations years ago and have focused on using the inherant 3D capabilities of ArchiCAD ... much more fun and efficient ... CD times have been cut way down ... changes are picked up throughout the plans with much less effort and errors!
