Redundant lines generated in Elevation/ Section Drawings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-10-24
06:40 PM
2023-05-17
12:56 AM
Gordana Radonic
David Rulon
- Labels:
Elevations
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-24 06:48 PM
->Publish the elev-sect as a pdf or EPS
->open in illustrator
->saveas as DWG
->import to AC and rescale if necessary
All extra lines should be gone. It is also possible that it works with pmk's substituting PM for Illustrator.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-24 07:57 PM
jdrulon wrote:Then don't. Believe it or not, it is perfectly possible to create elevations and sections without unlinking them or converting them to "drawing" mode.
Something that has frustrated me for a very long time when working in ArchiCad is the amount of clean up required when converting a 3D model to 2D elevations and sections.
It requires a little more discipline when building your model (pens, snaps, materials, etc) and you do have to darken a few things (usually polylines around the outline of the building), but gets around a lot of 2D/conversion headaches, and actually allows you to make changes while working in elevation view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 12:23 PM
jdrulon wrote:Only if you are not careful when doing the model. Take care of dimensions and snaps, assign materials properly, and do NOT think about the submission DRAWINGS before you have the BUILDING.
When the building is properly built, the drawings are a breeze.
Think of it as being on site - if you start properly, it might take a day/week or two before progress is visible to the nervous owner. After that, it is plain sailing. BUT, if you rush it out at the outset, so that the progress is visible, you will face many a snag afterwards, and therefore lose more time.
Reconsider your way of doing things; going to the dentist also hurts for a short time, but that perpetual nagging pain is gone.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 06:22 PM
David Rulon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 07:11 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 07:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 08:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-26 12:24 AM
Wow! This is the first time I could actually help someone, Im usually the one that needs help. I must be progressing...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-26 03:27 AM
David
