Learn more
Michael W
Reference 'Display order level'
In recent upgrades, the 'Display Order Level' has been added to the element information pallet (many thanks GS) but there doesn't seem to be a way to reference this information. To illustrate, I would like to
  • set up a graphic override to highlight different levels of each item;
  • find and select by different levels;
  • recall this information in an associated label.
These are mostly for QA purposes and not documentation output but it is all too common when working on larger teams to have this issue. A good example is that if a joinery object is higher than the adjoining wall, the line weight of the wall can be reduced because half of the wall line is covered.
Does anyone know if this is possible? Is it called something different or is it not available in these instances?
13th Gen Intel(R) Core(TM) i9-13900HX 2.20 GHz, 64 GB RAM, Nvidia GeForce 4050 Laptop GPU 32GB, 2 TB PCIe 4.0 NVMe SSD
1X32" (3840x2160), WIN11 PRO ENG, AC9-AC27
0 Replies 0
