‎2007-11-28
05:09 AM
‎2023-05-30
03:20 PM
Rubia Torres
‎2007-11-29 07:29 AM
Thomas wrote:Thomas, I must apologise, you are indeed correct about command clicking creating another node or witness line. After some feedback from graphisoft and further testing yes indeed two witness lines are created. The difference from 10 to 11 is the direction this newly created line extends. Stretching the wall reveals the two lines.
I think your problem emerges because what you really do is this: You're creating an extra (static) dimension node by command-clicking. Since it's horizontally at the same location as the old node, you're confusing Archicacd into that behavior.
‎2007-11-29 09:54 AM
sam66 wrote:Oh please don't feel like that! There's no need to apologize. Archicad is a big and very complex system. We all develop habits in our use of it. I'm sure you'd think I'm a fool too if you knew of some of my habits. Instead, I think we should appreciate the fact that it's flexible enough to accommodate to so many different work methods!
I feel like a bit of a fool using this method for so many years to move text when all I was doing was creating an extra witness lines. Please except my apology as I was sure this was an undocumented feature.
‎2007-12-03 12:29 PM
sam66 wrote:Watch us work it, Work it out, Watch us work it, Work it inside out!!!!Thomas wrote:D..E..V..O
OK. BTW, what's that hat you're wearing?
