Saving as a PDF in Archicad 7.0
I know we are behind the curve here but our office is still on vs. 7. I cannot get ArchiCAD to save as a pdf or to print to pdf. Is there a work around? I am on a PC platform.
5 Replies 5
Steve Jepson
are you using Adobe Acrobat or Amyuni .pdf converter that comes with ArchiCAD?
What version of either?
I think the PDF driver appeared in AC 8. So with earlier versions you cannot use it simply by installing Archicad.
As far as I know there are free PDF printer drivers on the Internet.
Thanks,
I will try finding some other drivers. Apparently ArchiCad 7 doesn't have the secondary program/support that 8 has. I have bought 2 pdf 3rd party programs which claimed they worked with any program but I have yet to get either one to work.
I don't know what are the various PDF solutions, but Amyuni, the one Archicad uses since version 8 installs a standerd printer driver. So in Archicad you actually able to print using the PDF driver but the result will not be a paper coming out of a printer but a PDF file generated from the print information.
I guess if a PDF solution is done this way, it should work with all programs that can print.
Djordje
Another user solved some Arabic PDF printing problems with free PDF printer from http://www.pdfmachine.com/?cl
Yes, any PDF printer/writer will print form any software.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
