Tarryn
Scaling fill Archicad 29
Is anybody having troubles with fills in ArchiCAD 29? I am unable to edit scales, or construction methods?
1 Solution
AllanP
That looks like bitmap display.
Have you tried turning "Vectorial Hatching" on?
View->On-Screen View Options -> Vectorial Hatching
sometime version changes turn off things like this that you will never think about again.
I hope this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Go to post
4 Replies 4
Can you provide a bit more detail? Which fill? Exactly how are you trying to edit scales? One or two screenshots would also be helpful.
Tarryn
I use the Construction method in the fill settings, or change the pattern unit size in the Element Attribute settings - nether make any difference? I have only had this problem since upgrading to 29
AllanP
I hope this helps.
Tarryn
Great that worked - Thankyou!
