MitchDes
Section Along a Polyline
Hi, can anyone tell me if it is possible to create a section along a polyline? I need to draw a section that follows a path (not a straight line). Is such a thing possible?
Using ArchiCad Start 2020 On PC With Ryzen 5 5600 6 core, 16Gb Ram, 64bit Windows 11, Nvidia RTX 3060 Ti, 32"; Lenovo Monitor; 1920 x 1080 Res
8 Replies 8
alemanda
Well ... It's not clear 100% what you want to obtain.
I can tell you that with the section tool you can have a broken section line (stepped section line), always along the same direction.
Otherwise you can make a 3D using the marquee (a polygon as you like) and create a parallel projection (elevation) from the point of view that you prefer.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
MitchDes
Thanks for the response. I realise that my question was a little vague, but it is difficult to explain. The section I want to generate is through a terrain mesh, and the section that I want to follow is 'U' shaped. It is a section through a driveway that doubles back on itself as it climbs the slope - like a switch - back road climbing a mountain. So I want the section to indicate the slope and slope changes along the course of the driveway. So I was hoping to be able to create the section along a polyline that is drawn on the driveway centreline (not straight or stepped), but angled, faceted or even curved. Hope this is clearer now, any help appreciated.
alemanda
Ok ... Now it's clearer
Actually you cannot achieve that at once
You should draw all the section lines along your path, save them as views and put together in a layout.
Of course your sections should have no projection depth.
AC27 latest hotfix
Win 11 Pro 64bit
MitchDes
Thanks for your help Alemanda. Sounds tedious, but I'll give it go!
vistasp
Mentor
There's a youtube video for doing something similar. It's not in English but you should be able to follow it.
https://youtu.be/hd40jeR5bVo
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
MitchDes
Thanks, Looks like a great solution but I can't get the majic wand to respond to to the curved line (or any line). Maybe it's because I'm using Archicad start (not the full version)?
David Maudlin
He is using the Interior Elevation tool, not the Section or Elevation tool. They are similar, but not identical.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
MitchDes
Well spotted David, That works!
Thanks to all for your help, much appreciated.
