Section cuts - resizing at the 2d level
martica
I placed a section cut on my drawing and it is too long. It exceeds the size of the residence. It is just sticking out there - too long. I used to be able to click on the section cut and resize it. However, I can longer do this. Can some one help me with the method to resize the section cut as it apprears on a 2 d drawing.
There should be a node in the centre of the marker head.
Drag it and use the 'adjust end node' option in the pet palette.
I don't have Archicad running at the moment, otherwise I would show you a screen image.
Thank you! it worked.😀
