Setting depth in Detail Drawing
Hi everybody,
I was wondering if it's possible so set a maximum depth for a detail drawing, just like you can do for a section (unlimited/limited/zero).
Thanks!
Enrico
Erika Epstein
No. The detail tool captures only what is visible with the active layer combination.
You could try altering the layer combination for what is visible.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Here is a trick/workaround you can try:
Create a Section for the Detail with the Horizontal Depth settings you want, then create the Detail Marker in that Section.
The Section would be limited both horizontally and vertically to show just the portion you need in the Detail. You may even place the Section line on a hidden layer.
When there is a change in the model, you can go to the Section, Regenerate it, then go to the Detail and regenerate that based on the Section.
