Shadow Display in Elevation
Lewis at Flourish
Archicad (27) noob here. Also Archicad forum noob...because I'm sure someone else has posted this topic but I can't find it
At one point in time, my elevations printed with a shadow like in the first photo.
Now I seem only able to print elevations with shadows displaying as an unsightly hatch (see second photo).
Could someone please clarify what I'm doing wrong?
Operating system used: Windows 3001
AC27 INT 3001
Windows 11 Pro 10.0.26100 Build 26100
MSI Vector 16 HX AI A2XWHG
32GB RAM | Intel Core Ultra 9 275HX, 2700 Mhz, 24 Core(s), 24 Logical Processor(s)
Lewis at Flourish
Thanks @Barry Kelly & @Lingwisyer - fortunately I was able to find an old version of the file that I'd saved off
The settings being used to achieve the desired shadow appearance as seen in my original post were:
AC27 INT 3001
Check in the elevation settings to see what fill/colours you have for the shadow.
Lingwisyer
Guru
I am guessing that you are using a 3rd party PDF printer given have the shadow fill has printed. Try using the inbuilt Publisher.
Ling.
Lewis at Flourish
AC27 INT 3001
Setup info provided by author
