Sheet Index Schedule - Using only one subset
Hello everyone,
I am working on my company's template and trying to organize the sheet index while keeping the layout in the navigator. My issue is that I like subsets to divide my project down of which the sheet index picks up every single subset rather than my top subset that I want on my sheet index.
How can I use only the top most subset in the sheet index?
I've attached a picture for visual clarity.
Thank you for your help.
Eduardo Rolon
Not possible unless you create dedicated indexes for each section which is easier and more practical than it sounds.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
AC27 US/INT -> AC08
another Moderator
Zinger
Hi there, Just wondering if you can tell me how you add subsets heading above each drawing?
Thanks!
I would like to know this too!
