‎2019-09-11
05:39 AM
‎2023-05-09
01:27 PM
Gordana Radonic
‎2019-09-11 07:17 AM
‎2021-04-19 08:50 PM
‎2021-04-24 12:36 AM
‎2023-04-06 07:28 AM
seems like this guy could scrpit it into a zone stamp tool. I guess question is, is how it was done and can we scrpit it ourselves into the current zone stamp tool?
https://www.indigofigs.com/zone-stamp/
‎2024-07-03 07:58 AM - edited ‎2024-07-03 07:59 AM
Hi, I was trying to find a similar solution to get my basic room dimensions to show up on a sketch floor plan for mine and my builders clients and real estate customers etc.
Sure you can just add your text to your zone stamp but it would surely be nice if it was automatic.
‎2024-07-04 07:07 AM
Hey, have you had a chance to check out the workflow I posted? I'd love to hear your thoughts on it. We rely on this workflow every day at the office. I'd be happy to discuss it further in a Zoom meeting if you're interested.
‎2024-07-04 08:47 AM - edited ‎2024-07-04 08:49 AM
Yes I watched the video you posted above and it was cool, we use metric units in my region. I am thinking of reaching out to CI tools to ask them if they can create a fill object that will do the trick for us.
‎2024-07-04 10:15 AM
What is meant by a "fill object"? I might be able to help you with that. The object I created is always linked to the zone, and it also has a 2D fill and a surface for the 3D window.
‎2024-07-04 10:52 AM - edited ‎2024-07-04 10:55 AM
The fill tool that can also show the area as in this tip link posted below. Sure the zone tool shows the area OOTB once a room is represented by walls.
This fill tool method is good for establishing the floor space ratio.
https://centralinnovation.com/technical-resources/learn/find-areas-quickly/
Can your GDL object that you created display the room dimensions in metric too ?
