Sink bowls go missing when printed
Ever since we switched to ArchiCad 11, none of my sink bowls print. They appear in the layout, but will not print. The faucets, when selected to be visible, print just fine. I'm guessing this is another bug, is there anything I should try?
Since it is a library object, I've tried selecting a different object, adjusting it, but nothing has worked. Initially I thought the problem stemmed from the object because it came from an 8.1 library. But when I switched it to 11, it didn't help. What do you think?
OH! Me Too!
Stephen Dolbee
I have noticed this strange behavior as well. When the library part is set at 0 degrees, it prints. Any rotation and it doesn't. I have just been drawing the sinks in until it is fixed.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
I have seen this happen before. I believe if you MIRROR the sink once it is placed in then it works fine.
