Mats_Knutsson
Mentor
Sketchy stacking order of 2D fills in Interior Elevations when Teamworking?
This is for AC23: (and older versions as well...can't tell about 24 or 25 since we use 19-23)
I draw a 2D fill in an interior elevation view and use display order to place it correctly. When a teammate opens the IE layout the display order is different. This is super inconvenient and I remember this problem from older versions as well...16, 17 something. It seems the display order is somewhat connected to settings on the client instead of the cloud!? I have no reminiscens of this happening with other views that IE.
Anyone else experiencing this? Workarounds? We've worked our way around this by assigning the task of creating the IE views/layouts to only one person (the person that did the 2D-fills) but in the large projects it's not a viable workaround.
Br,
Mats
AC 25 SWE Full
1 Solution
runxel
If I remember correctly the stacking order is only saved locally, meaning it will never be shared across different workstations in Teamwork.
If you think "this is a weird design decision" then you're absolutely right.
@Minh NguyenWasn't there some ongoing dev project to solve this problem?
Go to post
16 Replies 16
Erwin Edel
Is this teamwork or solo projects? With teamwork you are sending / receiving?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
Teamwork as the subject states 🙂
AC 25 SWE Full
runxel
Erwin Edel
No-one reads the topic, right? 😛
www.leloup.nl
Mats_Knutsson
Mentor
Design by forgetting some things and then not correcting.
AC 25 SWE Full
giza
In case you want to quickly check you can compare the Display order level of certain element if its the same for both users on teamwork, you may use Element information palete for that
Gezim Radoniqi | Architect |
Mats_Knutsson
Mentor
As Runxel writes the display order is local. I hope @mnguyen will comment. The behavior feels like a bug and is highly irritating.
AC 25 SWE Full
Mats_Knutsson
Mentor
Haha even the sun has its spots 🙂
AC 25 SWE Full
Minh Nguyen
Dear Mats,
Thank you very much for reaching out!
With the help of our colleague, we think that this could be an old defect with Teamwork operation. I haven't been able to get an exact confirmation on it yet. Once I know more about it I will let you know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
