Snap guides dont show middle point anymore? AC23
Ive recently swapped to AC23 for a new project.
In 21 I have been able to grab an object, then use a snap point circle thing and then that would give me a halfway point between the start point and the snap point.
I cant seem to do that in AC23 right away, is there a setting im missing maybe to turn on?
Thanks
1 Solution
You can set the snap options to 'Between intersecting elements', and this will give a snap midway between intersecting walls or other elements.
But it will not use objects as intersections, so in your image the vanity bench will not act as an intersection if it is an object, but will if it is a slab or fill.
But it could be that you were automatically establishing the snap guide lines just by dragging the element around and touching the edges.
This may establish intersecting snap guides that will give you a mid point.
I have never noticed a snap midway along the rubber band while dragging - unless it coincides with another guideline or edge.
This is what I would do.
Barry
Go to post
4 Replies 4
If you place 2 snap point circles, you should get the midpoint (so long as you have snap to 'Half' active).
Thanks Barry, in the past ive never needed two though, if i grabbed the object to be moved from a point and then made a snap point it would make a middle point in the past for me. Do you know if this is possible to set up?
Barry
Barry
Thanks for that Barry.
After seeing your post I tried doing it again your way and my way in a different area and both were working fine. Turns out my point was offset by 2mm so didnt notice it wasnt straight, I think this is what was causing my issue all along oops!
