Some superscript dimensions missing in Layout "Drawings
I have noticed lately that some superscript dimensions are missing
in layout drawings that are present in the project.
I am using AC 10 and have not noticed this in the old Plotmaker pmks.
Please see attached image.
I am wondering if others have noticed this and if someone has
figured out how to predict when it will occur and how to fix it.
Thank you,
Peter Devlin
16 Replies 16
Steve Jepson
It sounds like a View Setting dimension problem.
Fractions will not show if you don't have the Demension settings under the 2D/3D Documents tab of View Settings set properly.
Sorry I having trouble understand exactly where the settings are incorrect. I can't seem to locate "View Settings" or "2D/3D Documents Tab". Can you give me a hint?
Steve Jepson
With your Navigator window open, right click on a View, then click on View Settings. With the View Settings window open click on the 2D/3D tab. Next to dimensions, select a dimension setting that will display fractions.
If you have not set up a dimension display setting go to Options, Project Preferences, Dimensions and configure the dimension display.
Be sure to click on ADD when you have your dimensions configured the way you like it.
It is also possible to have the dimensions display in say 1/64" in your views and 1/4" or what ever for drawings in the Layout.
I can post some pictures if you still need some help.
No I got it... I already have that set up. The problem is that I prefer superscript fractions (fractions in small type) and don't like a 0 before fractions of dimensions less than 1". Unfortunately, the superscript fractions don't show up if the dimension is less than 1"... I've attached some screen shots....
For what it is worth the superscript fraction dimensioning works just fine in Archicad 12...
Is this a plot to force a move to metric?
Steve Jepson
I see. Not good. Work around is to use custom text.
By null at 2010-03-24
I've created a second dimensioning standard for details that have dimensions under 1"... I just don't like it and really when I'm detailing I could use the extra space and clarity created with the superscript fractions...
