2008-01-26
07:37 PM
- last edited on
2023-05-23
12:02 AM
by
Gordana Radonic
2010-03-24 06:54 PM
2010-03-24 07:23 PM
Steve wrote:Sorry I having trouble understand exactly where the settings are incorrect. I can't seem to locate "View Settings" or "2D/3D Documents Tab". Can you give me a hint?
It sounds like a View Setting dimension problem.
Fractions will not show if you don't have the Demension settings under the 2D/3D Documents tab of View Settings set properly.
2010-03-24 07:30 PM
2010-03-24 07:52 PM
Steve wrote:No I got it... I already have that set up. The problem is that I prefer superscript fractions (fractions in small type) and don't like a 0 before fractions of dimensions less than 1". Unfortunately, the superscript fractions don't show up if the dimension is less than 1"... I've attached some screen shots....
With your Navigator window open, right click on a View, then click on View Settings. With the View Settings window open click on the 2D/3D tab. Next to dimensions, select a dimension setting that will display fractions.
If you have not set up a dimension display setting go to Options, Project Preferences, Dimensions and configure the dimension display.
Be sure to click on ADD when you have your dimensions configured the way you like it.
It is also possible to have the dimensions display in say 1/64" in your views and 1/4" or what ever for drawings in the Layout.
I can post some pictures if you still need some help.
2010-03-24 08:01 PM
2010-03-24 08:07 PM
2010-03-24 08:12 PM
