Story Levels representation
Eduardo Rolon
I do like that AC copied the story levels option from Revit, since it is one less thing to dimension, but AFAIK the "correct" way to represent the Base level should be 0'-0" without the ± sign (at least that is how I was taught).
± can give the contractor the wrong impression.
Is it 0'-0" or can it be almost 0'-0"?
Can the contractor say "well, the elevation says ± so 1" error either way is not my problem".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
15 REPLIES 15
You're absolutely right, it doesn't make sense. The only time to use ± is to give a tolerance. ±0 is meaningless.
You can turn off the '+' in the settings of 'Basic Story Marker', which also gets rid of the ±, without affecting the negative sign. Or it wouldn't be too hard to hack the marker object itself. But they should still fix it.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Djordje
Not in European notification. It is not meaningless ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Eduardo Rolon
But mine is US not Int
AC29 US/INT -> AC08
another Moderator
Djordje
So?
Mine is INT and has feet and inches. Should I complain?
Djordje
HP Omen
Is it possible to change the story levels standard, so that 0'-0" shows as 100'-0"? This is a standard convention, but i don't see this option.
Help please... šŸ™‚
__archiben
unfortunately not. the biggest improvement to these storey levels now would be to choose a level datum from the three reference levels defined in the 'Working Units and Levels' preference.
~/archiben
b e n _ f r o s t
Djordje
Help please...
You can set the stories to any elevation you want.
Or did I misunderstand?
Djordje
HP Omen
i solved this issue, by raising the model to 100'-0"...
Djordje
... and now you have a problem when you have to specify the level of anything to the current storey now.
It is much cleaner to change the elevation of the stories. All the elements are still at the same relative height to a storey, the level dimensioning is automatic, as is the actual storey level.
Give it a try.
Djordje
HP Omen
