mukster
Story Lines in layout book
Archicad 27 on a MAAC platform - when I'm in the view map, looking at elevations, the story lines show up fine. However, when I go to the layout book, the lines disappear. How can I get them to show up on the layout book sheets?
8 Replies 8
Mehmet Katmer
Section settings > Floor levels
mukster
This is not an option on Archicad 27
runxel
Of course it is. You can choose within both sections and elevations if the story level markers should show or not.
Also be aware that only those stories with their checkbox in the story dialog activated are shown.
mukster
Not on mine. The lines show up on the view map, but not on the layout book . The story lines are all turned on
runxel
Please show us screenshots from your settings.
mukster
Screen Shot 2024-02-26 at 10.11.29 AM.pngScreen Shot 2024-02-26 at 10.11.22 AM.png
mukster
Solution: Figured it out. Have to go into the view map, right click on the elevation/elevation settings/click on Display & output on the story levels box
Lingwisyer
Guru
You can access the Elevation Settings by right cicking on the Elevation Marker, Elevation on the Project Map, or on the Placed View.
