2015-01-06
02:33 AM
2023-05-26
02:27 AM
Gordana Radonic
2015-01-06 04:04 AM
2015-01-06 03:18 PM
2015-01-06 03:56 PM
2015-01-06 04:48 PM
2015-01-06 05:08 PM
Erwin wrote:Thanks for the tip but I did try that prior and there is nothing on the layout or master, it is completely blank.
Go to the master layout, turn on all layers and then select all elements. There will be something there, perhaps it is a layer or pencolour issue that stops you from spotting it.
Check at "work environment > on screen options" if you aren't using some white pen to override master layout items.
2015-01-06 05:13 PM
2015-01-06 06:38 PM
Erika wrote:Yes I looked at the watermark setting and couldn't find anything to remove it.
you mentioned a watermark. Did you check the pdf watermark settings?
2015-01-06 08:08 PM
2015-01-07 09:18 AM
