Wall thickness
I have a following problem with the wall thickness. In my main computer the wall thickness works fine archicad 17, but in my main laptop the wall thickness takes only the values 1,2,3 etc. When i put the value 0.25 the thickness become 0, when i put 1.35 the thickness become 1 etc. My working units are meters with two decimals. Any ideas;
13 Replies 13
rob2218
Check your "Work Environment" settings. It's probably different from the laptop to the desktop. Also check the "Project Preferences" settings. Maybe same ussue.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Unfortunately the settings are the same. I unistalled it and reinstalled it and the problem still remains. Any idea;
rob2218
hummm.....ok.
well, let me mull this over a bit more.
Gurus of the forum.....any suggestions?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218 thank you!!!
It is so strange to work fine in the desktop and in my very good laptop to have this issue. I forgot to say that both have win 7 64bit
Link
This is usually set by your model units under Options> Project Preferences> Working Units...
Link.
Is there any round down function or choice in archicad that maybe enables and make the issue; I also checked the regional settings of my laptop which is bought from USA and i did found nothing strange. hmm... and the mystery keeps going on...
Link
Yes there is. You should also do a search for Region Settings in your Windows Search bar. From there click on Additional Settings.
Link.
Where is the round down function in archicad; In the regional settings (additional settings) everything is ok.
David Maudlin
getheod:
For display, look at Options > Project Preferences > Working Units. For dimensions, look at Options > Project Preferences > Dimensions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
