Strange issue with Vectorial 3D Hatching Display in Elevation
I have an issue with trying to display the vectorial hatching for a project I am working on. At first it seemed to work properly but when I went to my layout book to check the drawing the entire building displayed with a solid green fill. Returning back to the elevation and the wrong display is now on this view as well. Other elevations have the same issues. below is a screenshot and my settings. I would be greatly appreciative if there are any suggestions.
Thanks
Is there a Graphic Override (or possibly a Renovation Filter) active?
Minh Nguyen
Thank you very much for your question!
I agree with Barry, that there might be an active Graphic Override combination when you switch back and forth between different views and layouts. But, if you're sure the no Graphic Override combination is applied, please let me know and I would love to have a look into your project file.
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
