Surface vectorial hatching - 2 colours?
Hello, is there a way to get both a foreground pen and a background pen on vectorial hatching with surfaces?
For example, here I have a timber decking surface, I would like to have a black horizontal line pattern with a brown background, to simluate the material. But there's only 1 pen option. Any way to change this?
Or will I just have to continue to put the horizontal line drafting fills over the solid colour surface hatching?
runxel
Hero
It's all there (after the first time you grok how that works it is even logical!)
(Just make sure you have set uncut elements to "own surface color" in the section settings)
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
Perfect, thanks very much!
