Switch on several drawings underneath the current story
Is there a possibility with (or without) the Trace & Reference tool to switch on several drawings underneath the current story?
This is possible by creating a layout with all the required views and then using Trace & Reference tool for the work view
It's also one way to have a dynamic nomenclature in the 2D design space
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
Eduardo Rolon
Doesn't need to be a Layout. Can be a worksheet were you place all the Info
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Your request is equivalent to a method of work often used to notably make appear a nomenclature + plans of levels + a facade or two + 3D CineRender + etc. ...
With a worksheet it will not work ... especially for the nomenclature so convenient to check the m2 live
You need to do a layout or a worksheet as you want
Christophe - FRANCE
