ā2018-06-2703:23 AM - last edited on ā2023-05-1910:11 PM by Gordana Radonic
ā2018-06-2703:23 AM
Why does this symbol misbehave? When you place it the first time, it looks like the symbol on the top, which is correct, but after it changes to the symbol on the bottom, which is not correct.
I checked it out, and the NCS indicator label seems to be working properly for me. The Leader line doesn't even go that far, it stops at the edge of the text box or the header shape (depending on which is closer).
Maybe you are using custom GDL labels? If you upload a pln with this problem we can check it out.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
