ā2018-10-29
10:38 AM
ā2024-12-19
12:29 PM
ā2024-10-15 03:07 AM
Unfortunately I do not know any more that any one else that is not part of Graphisoft.
Like you I am just a regular user of Archicad, except I have moderation privileges on this forum.
I, along with many other members here, am also part of the 'Insider' group, so we do have a little more knowledge of what is going to happen and we have the opportunity to discuss that with Graphisoft.
But what is mentioned in the Insiders group is to remain in the Insiders group and is not for general discussion.
https://community.graphisoft.com/t5/Graphisoft-Insiders/ct-p/insiders
Applications are closed at the moment.
I too was affected by this bug just the other day.
It is only a very small change, but it is annoying.
I think the bug when copying text then zooming and pasting affected the size more, may have been fixed.
But this is just copying text within the same edit dialogue.
Here is a test I just did in version 28.
My guess was that it is converting to the closest point size or fraction of a point size, but that is not correct.
I will report this directly to Graphisoft as a bug, I suggest that all those affected also contact they local support and do the same thing.
"The squeaky wheel gets the oil" as they say.
ā2024-10-15 04:18 AM
I was thinking along the lines of someone storing the values as rounded fractional inches, which is a bit closer, but I do not believe is the case either...
