2022-04-06 04:11 PM
Hi All
I am relearning Archicad after a long hiatus. It's been going very well and the answers I've needed on this forum and on YouTube have been great. However....
I have a stair and I can not change its renovation status from existing to demolition. What am I doing wrong?
I've created a new stairs on both with both demolition and proposed to test this, but then can't change those either. I'm working in Archicad 22 on a Mac
2022-08-15 10:43 AM
Hi Felix,
I had this issue many times with a variety of different elements. Just solve the issue right now with a set of columns that wouldnt change its status. All I did was to change its distance to project zero. As soon as I did that, the Renovation status became available so I could change it. See if it works for you.
2022-11-30 04:07 AM
I'm not sure if this would work with relation to stairs, but I had a similar problem with doors once. Essentially, as the door was placed on a wall marked as 'New Construction,' I couldn't change the door to anything other than 'New Construction,' as it wouldn't be able to have existed in a wall that wasn't there prior.
Could it be that the stairs are linked to a floor (or both floors) that is marked specifically as 'New Construction' or 'To Be Demolished' and therefore turning off your ability to alter the renovation filter status of that item?
2023-04-21 06:54 PM - edited 2023-04-21 06:57 PM
Hi Felix,
Were you ever able to resolve this? I am running into the same issue with some roof rafters that were modeled as "new" when they should be "demo". The options to change renovation status are greyed out, and I cannot figure out why.
Even when I try to model new rafters, in a window where the construction status is set to "demo" or "existing" I am unable to model them in as existing or demo.
2024-04-02 02:21 PM
I had a similar problem today but with Polyline/Line and Library Objects. AC 27 Build4060. Not a teamwork file.
No matter what they didn't work, I was able to use them, but they didn't appear on Project/View map. I checked the classification options and both Renovation Status & Show on Renovation Filter were in grey and a day before they were okay.
For me the solution was :
Window > Palettes > Renovation Palette > Unpin whichever filter is active.
I don't have any idea what was the reason for this, but what I did could be the solution for your issue too.
2024-04-02 05:52 PM
Any chance the stair object was accidentally locked? If you have the object selected and go to Edit>Locking>Unlock does that help? We've had a couple users accidentally lock things before, think a shortcut may have been accidentally pressed. If that's not the case, hopefully one of the other comments help!
2025-03-04 01:22 PM
Hi. I am facing the same issue with patches - there is no option to change renovation status. However i can send them to desired reno combinations. Are patches not available as renovation status elements?
