Unit display in Schedules totals
Titiriga
Hello!
Is there a way to have the Total/Grand total field in schedules show just the value without the units?
Thank you
James B
We are currently working on this for the next main release of Archicad,
As indicated here - https://community.graphisoft.com/t5/Product-Roadmap/Interactive-Schedule-formatting-and-UI-improveme...
James Badcock
James B
James Badcock
We have the opposite problem, we would like to have the unit displayed with each value, not just the total. Is there going to be a fix for this problem?
Thank you.
Setup info provided by author
