2006-07-10
07:01 AM
- last edited
3 weeks ago
Aruzhan Ilaikova
2006-07-10 03:14 PM
2006-07-10 04:11 PM
2006-07-10 04:38 PM
TomWaltz wrote:That's the thing. Model true extent (so the trim works) and dimension to the framing. Composites are the only way.
K&A uses composite walls exclusively mostly because they do a lot of housing and wish to dimension to the stud but be able to show the finish to make sure the clear dimensions work.
2006-07-10 11:16 PM
James wrote:yep. and even with single-skin walls, composites are the only way to have the fill orientation flow with the wall direction . . .
2006-07-10 11:25 PM
~/archiben wrote:Didn't Link say that like 6 months ago?
(by the way, tom and others, a thought just occurred to me that careful use of pensets could in fact be a workaround method for showing 'core-only' of composites when required?? haven't had a chance to flesh it out yet, but . . .)
2006-07-10 11:36 PM
TomWaltz wrote:typical. i never listen.
2006-07-11 12:10 AM
~/archiben wrote:I've been doing that for some time now, mostly for sending DWGs to consultants. It's quirky in 9 but much better in 10.
...by the way, tom and others, a thought just occurred to me that careful use of pensets could in fact be a workaround method for showing 'core-only' of composites when required?? haven't had a chance to flesh it out yet, but . . .
2006-07-11 12:22 AM
2006-07-11 12:15 PM
~/archiben wrote:My AC 9 pen set was set-up for precisely this purpose. After a time I established dedicated pens for almost all elements. The most successful logic for me was based on material or element type—walls, doors & windows, fixtures, concrete, stone, etc. I ended up with small groups for each typically with pens for plan symbol, section cut, fill FG, fill BG, etc. I arranged all these toward the bottom of the pen table and created a generic set of pens at the top. After a time I was using only the dedicated pens with the help of a cheat sheet. The new pen descriptions in AC 10 will make this a lot easier to keep track of, especially in an office environment. This system not only enables lots of tricks on the layout side but allows the user to globally tweak the color and "puch" of one material or system relative to the rest. The US ArchiCAD 10 Default pen set in the newer US template is a modified version of this with only the Graphisoft and generic pens defined.
