Vector Fills - origin problem
This question may be dumb, and may well have been covered here before, but here goes anyway...
EXPLANATION ; A colleague is working on a project with many (8) housetypes and wants to see the brickwork coursing in his elevations. As is commonplace here in the UK he has set window/door heads and cills to correspond with brickwork courses and has set his walls to correspond with storey heights that are a multiple of brick courses, but the vectorial fills in his elevations don't start at the base of the wall, so the windows and doors look as if they at the wrong height in the wall. N.B this is not a rendering, just a section/elevation.
QUESTION: Is there an easy way to set the origin of the vector fill (representing brick coursing) so that it starts at the base of the wall, not slightly offset as it seems to do in the preset ArchiCAD vector fills for brickwork? Any example or purpose-made fills would be much appreciated, especially as - as usual - is a rush job!
12 Replies 12
Ben Odonnell
Mike,
It's pretty easy really. If you take a look at the attached image it will give you a pretty good picture of what you will need to do.
first you will need to in your fill settings, with the respective fills marked if you have already drawn them. You will need to select "Link to fill Origin"
You will also need to change your display options so that it shows fill handels, or you can down load the fantastic tool that our very own Karl Ottenstein has created for us, as shown in the attached image.
After you have taken these steps you will be able to move you fill origin freely.
BTW, don't forget to change to vectorial hatching in your display options as well.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
AHA!!
I thought the same, but if I am very much mistaken this does not apply to fills for walls seen in a Section, because there are no fill handles, as far as I can tell.
Use a wall with a vector fill applied to one of its faces, view it in a section and see if you can find the fill handle.
Please try it, because I would love to be proved wrong!!
Link
That's a different type of fill. In fact it is a 3D Hatch and you will need to select the wall in 3D and go to Edit>Align 3D Texture...
Make sure you view it at an angle because this function has a tendency not to work if you view it too 'straight on'.
Link.
Thanks Link, that's done it!
Gudday,
Thanks so much for that wall fill tip! I have been suffering that same prob too since beginning to use vector hatching in my elevs. I finally came here and searched for the problem and here we are!
Excellent! Looks sooo much better!
Thanks all!
Daniel Lindahl
Link.
G'day Link,
I know you wrote this a few years ago now but I'm now having trouble with it. I am trying to align the vectorial fill used in a material definition with the edge of the plane this fill is covering in an elevation. I can't find the 'Align 3D texture' in the Edit menu, when I have selected the wall in the 3D window. The texture on the wall looks fine, bur the vectorial fill that shows in the elevation doesn't....
Cheers
Daniel
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
David Shorter
There is an easier way to align brick courses with the base of a wall.
Simply open the log details (in the wall dialogue) and check the box which says align with wall.
Make this the default.
Then every wall hatching will start from the base of the wall.
Be careful with the brick textures though as some of the INT textures start with half a brick. Most of these have been changed in the Australian version
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Daniel Lindahl
Hi David,
Just checked that out and this already was the default. Its not the alignment vertically I have problems with, its horizontally, and the "align with wall" button doesn't seem to fix this. I have made special textures (and fills) showing expressed vertical joints in FC wall cladding. I know I can just draw lines on the elevations or place actual grooves in the wall to achieve this, I was just trying to automate it a bit more.
cheers
Daniel
NCornia
Graphisoft Alumni
Graphisoft Alumni
Link.
G'day Link,
Cheers
Daniel
Daniel,
The menu is listed in 'Design/Align 3D Texture'. The command you want is "Set Origin..." If you still do not see the menu and command then it is not present in your Work Environment. The recommended thing to do is to first save your current work environment profile if it is not stored already, then switch over to the Standard Profile 16 to make sure that you have all the new features of the release. Then you can customize a mix between the schemes of your custom work environment and the schemes of the standard.
To save your current profile:
A. Go to Options/Work Environment/Work Environment...
B. In the Work Environment dialog click "Work Environment Profiles" in the column on the left.
C. If your current profile is not listed amongst the default 3 profiles in the Stored Profiles field, then click "New Profile" to store your current configuration.
D. I then recommend that you export the profile to the area that you store your other documents and files for safe-keeping.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
