Volleyball Court Settings
Johann_P
I'm trying to change the volleyball court dimensions.
I believe the FIVB (Fédération Internationale de Volleyballl) beach volleyball rules require 8m x 16m
The settings seems greyed out and I cant seem to find where/how to change it?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
5 REPLIES 5
Podolsky
Ace
It looks like you cannot change these dimensions. It's limitation of GDL script.
You actually can try to open the script (if you know a little bit GDL) and try to modify it. Otherwise you can just explode the object into Morph and manually change it.
Lingwisyer
Guru
Well it is locked to the standard volleyball court size. Just save out a new copy as beach volleyball?
AC22-28 AUS 3001Help Those Help You - Add a Signature
Johann_P
I've opened and saved copies of the volley ball court, changed the parameters to what I need, and even deleted the "locked" command.
Still the court size remains unchanged and un-editable.
Any other advice perhaps?
Windows 10 Pro
DGSketcher
Legend
I opened up the library part and it looks like it has been hard coded with absolute values e.g. you would have to go step by step through the GDL scripts to make them parametric or change them to the values you want.
As has been suggested, if this is a one off case, you could just convert the object to Morphs and then stretch the morphs to what you need. If it's a repeating object then you could consider editing the GDL, or if you don't know enough or anything of GDL an alternative would be to save the morphed object as a module file (.MOD), that way should you need to change it there is only the one instance to alter. Once created you can Hotlink the Module file into your model.
With the Module option, I would open a new file, add the court on the ground floor, convert it to a morph, stretch as required and finally Save As a new module file. You can then return to you main project and import it with File > External Content > Place Hotlink.
This may help: https://help.graphisoft.com/AC/24/INT/#t=_AC24_Help%2F080_Collaboration%2F080_Collaboration-58.htm&r...
Podolsky
Ace
Or you just model your own court from slabs. Stretch the slab is easier and faster than modify a morph.
You also can save your new court as GDL object: File / Libraries and Objects / Save Selection As... / Object
