Sculptdesign
Wall Finishes Plan
Hi everyone.
Is there a good way to document wall finishes in plan? I'm currently using the finish label but it's not very efficient. I need to place then move and rotate the label to put it in the right place, then manually set if it's the inside or outside finish of the wall to record.
I've tried overrides as well but this overrides the whole wall (both sides) and not just the relevant finish.
There must be a better way of doing this?
Operating system used: Mac Apple Silicon 14 Sonoma
ArchiCAD 26 Solo - Mac
Leire Bilbao
I have the same issue.
I started to do it with a pen set in which the line of the finish is a bright colour and very thick and everything else is light grey and thin.
The label is still a problem though and need to manually check that I have the right code /the right side of the wall, both in plan and elevation
