‎2005-07-16
07:54 AM
‎2023-05-19
04:05 PM
Gordana Radonic
‎2005-09-09 10:00 PM
‎2005-09-09 10:34 PM
Also, would any beta testers be able share any future insights that would save me a lot of time setting up templates in regard to this topics? For future versions, is either direction a better choice to proceed on, for templates sake?We are bound by an Non Disclosure Agreement - and are unable to release information on future releases. So you may as well proceed on!
‎2005-09-13 02:35 AM
TomWaltz wrote:Just curious. What seems to be the problem with them? Mine seem to work ok.
I have yet to get Title Types to behave properly.
‎2005-09-13 04:07 AM
‎2005-09-13 12:01 PM
Steve wrote:I should have phrased that clearer: They technically work, but never really looked the way a drawing title should, with occasional multiple lines of text, a line that extends to always underline the text (for longer names). The View naming limitations in Archicad sometimes do not even allow a drawing to be named properly, let alone formatted properly.TomWaltz wrote:Just curious. What seems to be the problem with them? Mine seem to work ok.
‎2005-09-13 03:40 PM
I should have phrased that clearer: They technically work, but never really looked the way a drawing title should, with occasional multiple lines of text, a line that extends to always underline the text (for longer names). The View naming limitations in Archicad sometimes do not even allow a drawing to be named properly, let alone formatted properly.I'm still curious Tom - have you tried this lately? If you have text wrapping turned off there should be no multiline text problems. You can go a long way simply be using underlined texts and meeting them up with other lines. As for name length - sky's the limit ain't it?
‎2005-09-13 04:08 PM
Link wrote:Link,
I'm still curious Tom - have you tried this lately? If you have text wrapping turned off there should be no multiline text problems. You can go a long way simply be using underlined texts and meeting them up with other lines. As for name length - sky's the limit ain't it?![]()
Link.
‎2005-09-13 04:48 PM
‎2005-09-13 06:21 PM
Link wrote:That's fine if you want them all the same length. Graphically, they look better if a wider drawing has a wider text block under it....
Sure - just turn text wrapping on and define the size of the text block as you create the text (instead of double clicking). You can do that with any text block (autotext or not).
Link.
