‎2005-07-16
07:54 AM
‎2023-05-19
04:05 PM
Gordana Radonic
‎2005-09-13 07:38 PM
TomWaltz wrote:In your Master Title, make the line under your drawing name extra long.
That's fine if you want them all the same length. Graphically, they look better if a wider drawing has a wider text block under it....
‎2005-09-13 08:12 PM
That's fine if you want them all the same length. Graphically, they look better if a wider drawing has a wider text block under it....Well then turn text wrapping off and don't set the text block width - just double click and go!
In your Master Title, make the line under your drawing name extra long.You'd be better off simply stretching the individual title frame IMHO, and that's only if you can't get away with using underlined text.
Then stretch it to underline your drawing name.
‎2005-09-13 08:23 PM
Steve wrote:Then it's one extra step for every single view placed in a project AND you have to hope the name does not change in length for any reason.TomWaltz wrote:In your Master Title, make the line under your drawing name extra long.
BUILDING 1: MAIN LOBBY INTERIOR ELEVATIONIf you autowrap that, it becomes:
BUILDING 1: MAIN LOBBY INTERIOR ELEVATIONThe line underneath extends to match the text length, and you can make subtle changes to the name of the "drawing" without renaming the plan/section/detail view window and worrying about linking issues in Plotmaker.
‎2005-09-13 09:05 PM
Link wrote:Yes. Thats what I mean. You don't stretch the line. You stretch the title frame only if needed for extra long titles. It is not that much trouble if you have to manually locate the title frame anyway. I am thinking of times when I have details of several different scales and sizes on the same layout sheet and have had to turn the grid for drawing numbers off in order to get the drawings on to the layout sheet with correct title numbers.
Just my 2 cents.
Link.
