Why do i have thick lines when i export to PDF?
Hello
Oops didn't know my reply was the same so I was wondering if you could tell Mr a step by step tutorial on how to do this pen set thingy on archicad 19.
Thanks
3 Replies 3
Whether you print or publish to PDF, there is a "Hairline" option in the settings. But you're probably better off using Pen Sets correctly. You can assign a different pen set to your working (Project Map) view than to your view placed on the Layout, and use these to define line colour and thickness.
HI
Thanks for the reply but I'm not sure how to do this. 😕
Can you give me a step by step instructions on Windows 10 archicad 19 please.
Thanks you
ashwanikumarshukla
Hi Nerolex,
Same problem with me. Did you find solution for this?
Please help.
Ashwani Kumar Shukla
Archicad 12-26, 64gb ram, window 10
