‎2020-09-04
09:06 PM
‎2023-05-22
11:51 PM
Gordana Radonic
‎2020-09-04 10:47 PM
‎2020-09-06 07:33 PM
‎2020-09-07 09:17 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-11-10 08:30 PM
‎2020-11-10 08:43 PM
mnguyen wrote:Were you able to fix this in the upcoming build version? We are at 5005.
As far as I know, we had some reports about this behavior. Although most of them were fixed by recreating/replacing the schedule (as Thomas mentioned), unfortunately, we were unable to fix it completely, as there was a lack of information on how to replicate it. I would be extremely grateful if you could help us with recreating the issue!
‎2020-11-11 08:01 AM
Minh Nguyen
GRAPHISOFT
‎2021-03-18 06:31 PM
‎2021-03-19 11:57 AM
zoli79 wrote:Hello,
This issue seems to linger on.
Our template file is something that gets updated to the current AC version we are using, instead of starting a template from scratch whenever we switch to a newer ArchiCAD.
As recommended in this thread I recreated the schedule from scratch. Placed a few dimensions and finally placed the view on the layout. No dimensions on layout!
We use a clone folder for schedule views. This is where it gets interesting:
As a test I manually created a different view of the same schedule. This view did not display the dimensions I placed for a storefront (SF3). And vice versa: I annotated another window (SF4) from this manual view and these dimensions are not visible when opening the same schedule from the clone folder, I only see dimensions for SF3!
And the cherry on the top: the layout shows the dimensions for SF4, but the drawing itself is linked to the view in the clone folder. So when I right click on the drawing on the layout, choose open source view it shows dimensions for SF3, but not for SF4.
Minh Nguyen
GRAPHISOFT
‎2021-03-19 11:25 PM
mnguyen wrote:Yes, I would appreciate that! Thank you! I'll send you a PM.
I am wondering if it is possible for me to have a look at the file to know exactly what the problem is about? Please let me know if you will need a secure place to upload the file.
