Achille Pavlidis
Window schedule not showing related zone
This is really a big frustration!
I have set a schedule that lists doors and windows. After a lot of trial and error I managed to get all doors to correctly show their related zone name and number.
But not windows!
For some reason unknown a door in the same zone appears correctly on the list with its related zone, but the window next to it, with the same renovation status, position, etc, leaves the cell blank!
Is there any way to fix this???
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
22 Replies 22
I am not sure 'Related Zone' is really a good idea for use with windows and doors.
They should be using the 'To Zone' & 'From Zone' which is based on the orientation location click when you place the door/window.
You will probably find if you add a zone on the outside of the window (where you probably clicked to place the orientation) you will then get a 'Related Zone' as well - which is of course not what you want.
Achille Pavlidis
Hi Barry, thanks for the reply.
I used "Related zone number" because with "From" and "To" I always get some "Undefined" showing up in the schedule which I could't resolve. Maybe it has to do with the fact that this is a renovation project, and all doors and windows are new, but not all zones are new.
Anyway I cannot understand why Related Zones works fine with Doors, and not with windows.
I tried your suggestion, but still I didn't get the result. See attached image. Note that the door and window are placed on the same wall.
Also, why it is not possible to see from the door/window settings the related zone values?
It seems I was making assumptions about the 'Related Zone'.
I just tested by placing doors and windows with the orientation inside and outside of the zone and the related zone showed for all of them (there is no zone on the outside).
The 'To Zone' and 'From Zone' work as expected with 'Undefined' where there is no zone.
I don't use the renovation filters much but I believe the zones need to be the same status as the doors/windows.
For some reason I can not post any images at the moment.
I have changed browsers.
Here is the image.
Achille Pavlidis
Thanks for the replies Barry.
I was going nuts with this because I couldn't understand what was going wrong. So I started a new project from the Graphisoft template. There everything worked as it should, so I started to try and understand what was different from my file.
It turned out the problem was with the zone... For some reason even if I was using the zone stamp from Library 24, the zone was created from an old favorite and didn't relate correctly to windows. Once used the zone from the GS template everything worked fine.
Savino
Hi everyone,
I am just experiencing the same issue as per this topic.
At this stage, I have read lots of articles from the Graphisoft community in order to understand what could have been the issue but I am still going around the model, checking and comparing parameters without any success.
I have attached a screenshot of my window schedule list, please let me know what else I could provide you in order to understand what could be the issue.
FYI: I have checked the zones heights and location, made sure that the zone stamp touches the walls, etc.
Also, in case it could help, I am working on a BIM cloud.
Thank you in advance for your help.
Hi Savino,
Have you tried everything that Achille and Barry are talking about in this thread?
Savino
Hi Laszlo,
Yes, I have. I believe it is something minor that doesn't allow me to display the zone names on certain windows.
However, I have arranged a call with our Archicad mentor in order to check what is the issue.
On the other side, I would like to ask if there is a way for me to show a column mentioning which window has a blinder. In this project, we are using concealed blinds.
Thank you for your support.
I have checked this in AC25 Update 2 and it works for me. The "Related Zone Name" field returns
1. If the Window's Wall has Zones on both sides: the same value as the "From Zone" field.
2. If the Window's Wall has a Zone on one side: the Zone, be it the same value as either the "From Zone" field or the "To Zone" field.
3. If the Window's Wall has no Zone on either side: the value "<Undefined>".
(It would be beneficial for you to include your system specs and Archicad version in your signature. Some of these features have improved in the latest versions.)
