AnitaEicher
Windows tool AC27 - dimension
I have a window from the ArchiCad 27 library. I configure it. Everything is fine until... until I change the width of the splay return. If I leave 6cm, my finished and raw dimensions are ok. But if I change the value to put 10 cm, well, my finished dimension bugs... I no longer have the height value. On the other hand, the gross value is ok.
The result with a splay return of 6cm
 The result with a splay return of 6cm. The value "253" disappears.
2 Replies 2
AnitaEicher
And I just noticed that the height value doesn't match the actual values ​​for the finished dimension. The rating shows 253, when I should have 225
AnitaEicher
Hello.
Is anyone else facing this problem? Or is Graphisoft aware of this issue and will it be fixed in the next update?
Thank you for your answer.
